cat 22 clutch...how to unstick it?????????????????
ronnnioe
09-24-2004 00:49:04
anyone got any ideas on how to unstick a cat 22 with a stuck clutch? can you access it through the bottom? thanks averyone.
Dale(MO)
09-27-2004 10:22:05
 Re: cat 22 clutch...how to unstick it????????????? in reply to ronnnioe, 09-24-2004 00:49:04
One quick-fix that I have had good luck with is to plug the clutch case and fill it up past the throwout bearing with kerosene or diesel. Take the tractor out and run it (under load) until it breaks loose. I"ve had some take an hour or so, some just a few minutes. As soon as it breaks loose, drain the kerosene, readjust if needed, and run it until the clutch dries out completely. It will be a little grabby until it dries out. You may also have to tighten the clutch up when the kerosene is in the case - sometimes it will need to be opened a little more than normal in order to break loose. After it dries out, check to make sure everything is functioning properly (throwout bearing, linkage, etc.). Good luck!
