More TEREX Loader Questions.
Swedeguy
09-28-2004 11:00:54
I think I know it`s a 72-31 that I have, with a 4-71 Detroit Diesel. Does anyone have any repair related info about this engine? Have heard it`s difficult to adjust the valves and the governor. Appreciate all the info I can get. Thanks /Dennis
Roy Suomi
09-29-2004 20:02:26
 Re: More TEREX Loader Questions. in reply to Swedeguy, 09-28-2004 11:00:54
Why are you adjusting valves?? Noisey??or Bored??The only valves you are adjusting are exhaust valves, It ain't got any Intakes to adjust.. Run 'er like you stole it ..Detroits love it..
dsldr
09-28-2004 18:01:39
Valve adjustments are easy. Governor adjustments are a bit tricky, but not rocket science. Injector adjustments that are done during valve adjustments require a timing tool that is easy to use, inexpensive, and available through Mac or Snap-on. Check around your area, if you can not find the tune up info, get back on here and post- I'm sure either myself or someone else will have the info.
