350 B John Deere Track Loader
Jack Blackburn
08-08-2001 18:53:48
I have 1971 350B John Deere Track Loader. I need to remove the tracks. Can not find master pin because of wear on tracks. Can any one help me find the pin or help me get the tracks apart?
Half Track
08-09-2001 03:45:38
 Re: 350 B John Deere Track Loader in reply to Jack Blackburn, 08-08-2001 18:53:48
I assume by worn tracks you mean the pin bosses are beat up & wore. Therefore you can't tell one from the other. Odds are you have a flush type rail, so all the bushings are like master bushings. So you could remove any pin & it will come apart. You can tell if's flush type by looking in the joints. You should see the pins & not covered by the bushings. Good Luck HT
S Bogusta
08-09-2001 11:08:52
 Re: Re: 350 B John Deere Track Loader in reply to Half Track, 08-09-2001 03:45:38
Jack, I have a 350B dozer, I found the master pin yo be the one that looked all F___D up. To remove the pin I welded a 7/8 rod about 14 inches long to a handle about 36" long. I heat up the bushing w/ a rosebud tip, Get it cherry. Position your driver on some blocks of wood, with good position,
drive the pin through with a sledge. You may need to jam some steel plate betwwen the track and the frame, to prevent the track fom just moving when you hit the pin.
Hope this helps Ps I can E mail you my 350B page
Steve
