TD-14 Injector Pump
Dr Cy Kosis
10-01-2004 07:11:06
A friend has just had his injection pump rebuilt for his TD-14 and needs to know how to put it back in time with the engine. Any pointers I can relay to him?
captain_crunch
10-03-2004 09:45:16
 Re: TD-14 Injector Pump in reply to Dr Cy Kosis, 10-01-2004 07:11:06
Doc Come over to Red Power Forum There is lots of IH info there and also tips on how to fine tune the timing It has to be right or you can crack head with improper timing
Brian
brianh
10-03-2004 05:45:47
Just line up the line on the pump hub with the line on the drive gear. Put the three bolts with the pointer in and you're good to go. Start with the timing pointer at 0 till you're ready to fine tweak it. Brian
JerePa
10-01-2004 18:00:47
I have installation & timing proceedure from the ser. manual. Can send it to you. To long to type here. jndwissler@dejazzd.com
Dr Cy Kosis
10-01-2004 18:53:32
 Re: TD-14 Injector Pump in reply to JerePa, 10-01-2004 18:00:47
Thank you.
I Zapped an E Mail your way.
