JD 450 Final drive oil or not
motorhead460
10-03-2004 20:46:15
Was also wondering if the final drives should be oil filled or not,and what type oil it takes if any.I know it has dry clutches and steere brakes that don't need oil but was wondering if I need to check the final drive and how to do that.Thanks again,Rick
Pete/ME
10-04-2004 03:00:26
 Re: JD 450 Final drive oil or not in reply to motorhead460, 10-03-2004 20:46:15
If it's the same as my 350, there's fill and level plugs on the bottom inside of the drives. A manual will help.
PD Mechanical
10-04-2004 07:48:41
 Re: JD 450 Final drive oil or not in reply to Pete/ME, 10-04-2004 03:00:26
third party image
The fill and level plugs are one in the same and are located in the back of the final housing. And yes they should be checked periodically for proper amount of gear lube.
