used parts jd backhoe
r. kizziah
10-05-2004 18:12:46
i am looking for used parts or savage yards to purchase parts for a john deere 410 backhoe. i need now a part on the steering. rt side top piece that holds the shaft that holds the spindle on.
M Swantek
01-02-2005 09:22:46
 Re: used parts jd backhoe in reply to r. kizziah, 10-05-2004 18:12:46
R.
did you find any help on this? My dad has the same problem with his and is looking for the same part. And we just started looking for parts.
Any advice will be appreciated.
M in minnesota
Roy Suomi
10-05-2004 20:18:06
Most of those steering " knuckles " worked loose after a short time. Deere's fix back in the late 70's , early 80's was a kit . It contained a new knuckle a caulking tube, and liquid steel. We mixed the liquid steel put it in the caulking tube and injected it into a hole that was drilled in the side of knuckle and let it sit for a while til it hardened. I have ground both the knuckle and top of spindle and welded them with 7018..
