D-6 8u steering
Drydobber
10-07-2004 20:27:39
I have a D-6 8u caterpillar that has been in the family since 1957, purchased new. I have used the tractor for 31 years and it was last used in Dec. 2003. Today I started it and found the left track is non-functional...not engaging. If I pull the right friction the tractor stops. It was working fine when I parked it last December. does anybody know whats going on? I would sure appreciate any information! Thank you.
Bob/Ont
10-08-2004 18:21:58
 Re: D-6 8u steering in reply to Drydobber, 10-07-2004 20:27:39
I think there are a couple of plates you can take off the back of the bevelgear/steering clutch case to look into the clutch compartment and see what is going on. You need someone to drive the tractor forward as you follow and look inside with a light. Find out if the shaft into the clutch is turning and if the brake drum is turning when the RH Clutch is released. If both are turning the problem is likely in the final drive. Did the LH brake feel funny compared to the RH brake when you last used the tractor? Come on back with what you find.
Later Bob
