955L Clutch
Bob Blake
08-11-2001 06:03:10
I have a +-1978 Cat 955 L and all the hydrolics stopped working. There are 3 pair of rubber disks that appear to be worn out.(melt down)between the engine and transmission. Does anyone know if this is the clutch assembly and will replacing the rubber plates fix the problem?
Bob Blake
Moseley, VA
D Smoker
08-11-2001 18:50:58
 Re: 955L Clutch in reply to Bob Blake, 08-11-2001 06:03:10
The rubber discs are the isolators between the engine and the torque converter. If the discs are broken the tractor won't move. The hydraulics won't work because the pump is driven off the torque converter. Replace the discs, it isn't a particularly difficult job, once you get the loader up.
