JD450 backhoe
Phil - MO
10-13-2004 11:34:07
I have a JD 450 crawler/loader with a counterweight on the back.
I'm getting ready to build a house on the farm, and a backhoe would come in handy for the drain field etc.
Wonder what it would cost to put a backhoe on it?
Roy Suomi
10-13-2004 19:52:49
 Re: JD450 backhoe in reply to Phil - MO, 10-13-2004 11:34:07
Well first of all the counterweight has to come off if it's bolted to the back of steering clutch housings.A power beyond fitting for the loader control valve , hoses to the backhoe and quick couplers. Probably $ 300- $400 in above parts. Next is to find a suitable backhoe and mounting brackets to fit your machine. They're out there , you just hafta look around.Also make sure that the backhoe has an open center valve by blowing air thru the oil in and oil out hoses. I ran into one that was closed center and the pump didn't care for it much..Hoes usually go for around $ 2500.00 used..
barryinmn
10-16-2004 17:06:05
 Re: JD450 backhoe in reply to Roy Suomi, 10-13-2004 19:52:49
I have a quik tach JD 93 hoe with 36" cemetery bucket & all manuals. It fits my JD 350 dozer will fit 450 as well, takes about 2 mins to attach. The hoe digs 13.9 reaches 15.9 ~3K lbs. I normally run a rubber tired TLB to dig. So might be available.
