Please offer advice!
Jeremyinindiana
10-17-2004 18:58:23
I hope someone can help. I rented a little "Teramite" backhoe to drain a pond. It ran out of fuel "diesel" and now it wont start. It is a perkins engine if that helps. I filled the filter and kept trying with no luck. I hope someone can help, a mechanic isnt really in my budget. Thanks!!!
Sid
10-18-2004 21:58:35
 Re: Please offer advice! in reply to Jeremyinindiana, 10-17-2004 18:58:23
Since it is a rental if you look around you will probably find decals with instructions on how to bleed the fuel system. Some of the newer Perkins desiels have an electric fuel pump and that makes it easier to bleed the air from the fuel system. My advice would be call the place you rented it from. Let them either tell you how to do it or they can send someone out. If you have to pay a service call that going to be cheaper than screwing something up and having to pay for real work done on it.
JMS/MN
10-17-2004 21:21:19
You have air in the fuel system and need to prime and bleed it. Most diesels have a hand-operated primer on or near the fuel pump. Consult the manual for the procedure. Likely need to crack loose- not remove- the fuel lines at the injectors and pump the primer until clear fuel, without air bubbles, appear.
