Cat D2 injection parts
Davey
10-20-2004 07:41:43
was looking at a rope pony start d2 the other day for sale, been sitting for a while, pony motor started on first pull but the guy had to bleed the air out of the injector lines to get it to fire up and it did very well but it sounded to me that it never hit on the fourth cylinder. didnt run it very long, don't know if there was still air in the lines. are injection pump and injector parts still availible, in case it is something more serious and are they reasonably priced? we are talking cat here.
Bob/Ont
10-20-2004 16:48:31
 Re: Cat D2 injection parts in reply to Davey, 10-20-2004 07:41:43
You likely can get everything you need Davey. First off get it running again and bleed all the lines at the pump again. You should hear the engine run rough when you crack each line, if you do it's firing on all of them. Watch the stack for any signs of a white puff of smoke coming out regularily if it is missing. Then crack the lines one at a time untill it goes away then you know what cyl it was coming from. Good luck with it.
Later Bob
