Komatsu d20 dozer
Trey
10-21-2004 18:24:08
I have been wonting a small dozer to keep here on my farm, I will only need it to do very light work at times, pushing dirt around, keeping up fence rows, small stuff like that. I was wondering how the little Komatsu d20 type dozers are holding up? I am very careful with all my equipment keep it up at all times oil changes all that, I just dont wont a dozer thats will be giveing me alot of problems...when i get ready to use it I wont it to be very dependable. What about parts for it also? Are they easy to get, are they high?
Thanks Trey
Frank Dodson
10-21-2004 19:28:55
 Re: Komatsu d20 dozer in reply to Trey, 10-21-2004 18:24:08
First look down the forum at my request for Mitsubishi BD2F(same size as Komatsu) sprockets. I am having a hard time finding them. From experience I have owned three crawlers an Oliver OC4, Komatsu D20 and the Mitsubishi. I restored the Oliver and it looked so good that I didn't use it and sold it to someone who wanted it real bad. As for the Komatsu it had pedal steer and with a gear transmisson I didn't like the handling. I bought the Mutsubishi at what I thought was a bargain but now will have to put a few thousand on the undercarriage. The Komatsu is about the size of a JD350. If I had it to go over again I would buy a JD350. Parts are readily available however any work on the undercarriage will be expensive. Just my two cents.
JimInOz
10-21-2004 22:14:38
 Re: Komatsu d20 dozer in reply to Frank Dodson, 10-21-2004 19:28:55
For light dozing ,I think the D20/21 or BD2 are great...they do a wonderful finishing job & hire out rate is very good.However,parts backup is a problem,especially with powershift trans parts.Undercarriage is same as any machine.....expensive!I"m currently having more problems getting good backup for my JD350,than I ever had with Mitsubishi.If you can find an importer ,they may help with parts,but Komatsu dealers may get what you need.My local Mitsubishi Grader agent gets anything I need for my BD2 dozer.
I think Cat Worldwide are currently selling Mits dozers,so they may supply backup too.
Frank Dodson
10-22-2004 16:40:22
 Re: Komatsu d20 dozer in reply to JimInOz, 10-21-2004 22:14:38
JimINOZ
Would you mind sharing where you get Mitsubishi parts?
JimInOz
10-22-2004 22:06:45
 Re: Komatsu d20 dozer in reply to Frank Dodson, 10-22-2004 16:40:22
Here in Australia,BT Equipment sell Mits Graders & engines....they have several outlets.As I previously mentioned ,Rhine Equipment Co in Tacoma have helped me in the past also.A friend of mine does trips to Asia & sometimes gets parts too.I've heard stories of guys in rural areas getting bits from sympathetic Cat guys too.Also found local Mits forklift guy OK.They are a well built machine,but if any gears,etc go bad,you can always get a gear maker to make one.Persistence is the key..... ..... ..... ..!I'm finding that sometimes you can spend a lotta time stuffing around after parts for more popular brands,so the "bad" reputation of the small import gear isn't such a factor now.
