450B JD Engine
Jeff west/TN
10-23-2004 13:03:07
I'm into rebuilding my 450B, when I pulled the engine for rebuild, cracks were found in both the block and crank. This isn't a supprise I guess due to the low oil pressure.
Can anyone direct me to a salvage yard that might have these parts or a good place to buy a reman engine.
motorhead460
10-23-2004 21:04:33
 Re: 450B JD Engine in reply to Jeff west/TN, 10-23-2004 13:03:07
Hi,what size engine are you working on,is it a 4-276,4-202,4-239,4-219? turbo or not? I may know of some parts depending on size,but will have to check. Thanks,Rick
Jeff west/TN
10-24-2004 13:23:11
 Re: 450B JD Engine in reply to motorhead460, 10-23-2004 21:04:33
Mine is a 4-202 engine. I think a 4-219 no turbo will work as well.
Jeff west/TN
10-27-2004 11:52:34
 Re: 450B JD Engine in reply to Jeff west/TN, 10-24-2004 13:23:11
Email me with the info. What you want for it and etc.
motorhead460
10-24-2004 17:34:19
Hi Jeff,I am in East TN. I think the engines are the 300 series they all should mount the same and swap out easily.The 4202,4219,4239,4276 should all work.I have a plain 450 that had the 4202 and I swaped in a 4276 with no troubles,I also have a 310B backhoe that has a 4219,and a compressor that has a 4039,they all mount and look the same.I also have a spare compressor with the 4039 engine that has only 600 hours on it,I would be willing to sell if your interested,email me.I'll look around in my area and see what I can find as far as cranks and blocks.Thanks,Rick
