1948-D-4
Sam-Ga
10-25-2004 08:35:58
I looked all over (back,sides and and under the seat) for the ser.# can't find one.I know that it is a 1948 - D-4 with hydraulic blade,anyhow do any of you know the name and or number of the carburetor that is on the pony motor? How do I pull start this tractor(diesel engine) Thanks in advance.Sam
Bob/Ont
10-25-2004 10:08:49
 Re: 1948-D-4 in reply to Sam-Ga, 10-25-2004 08:35:58
Sam when you are looking for a serial# look at theLH rear of the back surface of the steering clutch case. If there is no plate look for signs of two rivet holes about 2 1/2" apart where the plate was fastened. Clean off the metal and look for a serial# stamped in the case. The side of the engine should have a plate on it too and they both share the same serial #, It will likely be a #U####. You can pull start it but make sure the trans is in the same direction as you are pulling or the engine might start up backwards. The fan should be rotating counterclockwise as you see it from the seat.
Later Bob
