Deere 440 battery ground
JDOUG
10-25-2004 09:57:57
I have a customer with a Deere 440 dozer he just purchased. I wants to know if the elec. system is positive or negative ground. We have no info here at the dealership on these. The dozer has a 2-53 Detroit engine. Thanks in advance.
Lavoy
10-25-2004 15:59:53
 Re: Deere 440 battery ground in reply to JDOUG, 10-25-2004 09:57:57
It is positive ground.
Lavoy
JDOUG
10-25-2004 16:28:40
 Re: Deere 440 battery ground in reply to Lavoy, 10-25-2004 15:59:53
Thanks. The cables were gone along with the battery when he got the dozer so he had nothing else to go on. Thanks again for the info.
Ol Shep
10-25-2004 15:35:15
How about seeing which battery post is connected to a ground source and which gos to the starter
RAB
10-25-2004 13:56:36
Like Bob says, or just let your customer check out the battery, if fitted. It will one or the other to ground, somewhere near the battery, or he could put a put voltmeter across earth and starter motor feed to check polarity.
Regards, RAB
Bob/Ont
10-25-2004 11:34:51
Doug, If it has a generator and regulator set up, look at the regulator. Clean off the metal base and it should be stamped with a number like 12 for 12 volts and a P or N for the ground polarity.
Later Bob
