wheely problem
Al in Michigan
10-28-2004 16:07:36
My JD450C is doing them....because I added a model 9500 backhoe on the rear. It made the dozer heavy in the rear and it does wheelies when I go over a small rise in the terrain. Any ideas as to how I can add weight to the front/blade area?
old
10-29-2004 20:56:57
 Re: wheely problem in reply to Al in Michigan, 10-28-2004 16:07:36
Don't know if this will help but I have an 8N Ford with a backhoe on it and up front behind the loader it has a cement weight thats is around 500lbs. fits in a sort of half V slot. With out in on the tractor you can't move more the a foot or so.
marlowe
10-28-2004 18:49:50
don't have JD but have a case 450 with hoe on back and with the hoe they make a 750 lb. weight that goes in front on the bellie in place of the skid pan
barryinmn
10-28-2004 21:02:59
 Re: wheely problem in reply to marlowe, 10-28-2004 18:49:50
I have a 350 with a #93 hoe & cemetery bucket. mine does a nasty wheelie too. (Trakkie!) Are the belly weights available on the 350 frame as well?
marlowe
10-29-2004 17:15:20
 Re: wheely problem in reply to barryinmn, 10-28-2004 21:02:59
same weight as the 450
MrBill
10-28-2004 21:15:47
I have a 350b with the #93 hoe. Not only was I doing wheelies, I also was messing around in the trees and a track jumped sprocket. Hine site said, I was lugging around way too much weight which was hard on the whole machine.
Now, I only hitch up the hoe when I am ready to use it and take it off when I am done.
It is a lot easier to pop the hoe on and off than it is to put a track back on the sprocket.
But I would not trade that #93 for anything. A dozer with a hoe is one handy machine!
MrBill
Al in Michigan
10-31-2004 05:11:04
 Re: wheely problem in reply to MrBill, 10-28-2004 21:15:47
Indeed it is. With a trailer or dump truck, what else could a person need to rearrange the earth to your content?
