New Holland LS-150 Skid Steer Antifreeze Leak
Wayne Mo
10-31-2004 21:37:28
My 2002 New Holland Skid Steer LS-150 is losing antifreeze but I cannot find a leak. The motor has less than 300 hours on it. I topped it off today up to the radiator neck and will check tomorrow if it goes down any. I don't use it much but I topped it off a month ago and it is down over a quart. I don't know if it looses it running or just sitting there. I will watch it from now on and try to determine. Does anyone know of a problem here like this? It is so crowded in the engine compartment it is hard to see much!
chvet73
11-02-2004 07:40:40
 Re: New Holland LS-150 Skid Steer Antifreeze Leak in reply to Wayne Mo, 10-31-2004 21:37:28
You need to get a pressure tester. Fits on the radiator cap. Pumps up to a low pressure, like a cooling system runs at. You need to warm it up first so the thermostat is open. With the pressure you can then find the leak if your lucky.
