IH DT 340 with a D166 engine GLOW PLUGS !!!
Jonathan Carr
11-04-2004 06:36:38
I need to get some glow plugs for my dt-340 anybody have any Idea's ???
K.B.-826
11-05-2004 19:53:04
 Re: IH DT 340 with a D166 engine GLOW PLUGS !!! in reply to Jonathan Carr, 11-04-2004 06:36:38
Case-IH dealers will have them. The D-166 is the four-cylinder version of the six-cylinder D-236, D-282, and D-301 engines used in many IH tractors and combines in the late '50's-'70's. They'll be the same as a Farmall 560 Diesel tractor.
Oldfarmboy Jim
11-04-2004 18:23:30
Komatsu Dresser dealer near me carries some T/TD-340 parts. The Case dealer carries some IH engine parts. The D166 was used in a number of IH/Farmall tractors, so salvage yards may be able to help you also. Good luck.
the tractor vet
11-04-2004 11:44:49
Case IH same glow pulgs as a 340 Int. or Farmall .
jonathan carr
11-05-2004 05:19:52
 Re: IH DT 340 with a D166 engine GLOW PLUGS !!! in reply to the tractor vet, 11-04-2004 11:44:49
I need at part # probably. Does any one have the the part # for the glow plugs in at D166
Charlie
11-05-2004 05:48:08
 Re: IH DT 340 with a D166 engine GLOW PLUGS !!! in reply to jonathan carr, 11-05-2004 05:19:52
I can get the number for you this weekend when I'm up at my camp in NH, where I have my manuals, but I do think that the engine number, D-166, should be good enough for Komatsu (IH construction line), or Case (IH ag line), or maybe even NAPA.
jonathan carr
11-05-2004 08:04:57
 Re: IH DT 340 with a D166 engine GLOW PLUGS !!! in reply to Charlie, 11-05-2004 05:48:08
If you could get the #'s I would be grateful. thanks again
Charlie
11-06-2004 05:42:33
 Re: IH DT 340 with a D166 engine GLOW PLUGS !!! in reply to jonathan carr, 11-05-2004 08:04:57
There are two interchangeable glow plug numbers in the TD340 parts manual. Each is listed as an optional replacement for the other. They are:
304131R2 and 343894R1
Charlie
11-06-2004 05:40:41
kjm
11-05-2004 19:02:01
jonathan,The part # should be on the glow plug at the base. Most auto parts stores should be able to find them for you, but check the price. Sometimes the dealer is the best deal.
