JD 1010c stuck steering clutch
Glenn
08-17-2001 08:24:24
I just got a 1961 1010c that is in great condition except the right steering clutch is stuck. With a D2 CAT you can put diesel in the clutch compartment and try to break them free, or push against a big tree with the clutch handle pulled back, are there some simple thing I can try with the 1010 before pulling the clutch assembly apart?
Thanks, Glenn
Jerri
08-18-2001 06:24:00
 Re: JD 1010c stuck steering clutch in reply to Glenn, 08-17-2001 08:24:24
Glenn,
Have heard the same thing about adding mineral spirits or some say diesel and use the clutch/brake and this will sometimes free it up. I have not done this, but have it on authority from some old timers that it will work. If you do it, do not forget to remove the drain plug and drain the fluid when finished.
BTW, I have a 63 1010c, but still going thru her and not put her to work yet.
Jerri
