T-340 PTO
Jackmcg
11-11-2004 08:38:35
My IH T-340 has a plate on the rear that looks like it could be removed and replaced with a PTO. Anyone familiar with these? Is it the same shaft and 540 RPM like a regular tractor PTO? Anyone know where I could get a PTO assembly to fit?
Thanks,
Jack
Harold H
11-14-2004 18:23:31
 Re: T-340 PTO in reply to Jackmcg, 11-11-2004 08:38:35
The T-340 pto was optional but I don't know if the non pto crawlers were equipped to accept the pto or not. I would suggest you head your crawler down hill and remove the rear plate and check internally to see if there is the stub shaft that accepts the pto shaft or not. If it is there, get a pto from a tractor in a salvage yard and insert it in your crawler. If it does not have the stub shaft, (about 18" or so ahead of the rear plate if I remember correctly) you will have to forget the pto idea.
Harold H
Charlie
11-13-2004 07:10:29
I have the same machine with the plate and the scarifier, and have always wondered about the PTO capability. If you find out anything more, would you please post it here and on the T-340 discussion group. Thanks.
G. Lee
11-12-2004 16:15:33
Jack,
I have a TD-340 that has a PTO.Appears to be same as 340 tractor except the lever that engages the pto.The drawbar is also different.The dozer don't run well but I don't want to sell the PTO off it.I live in NC.Where are you?
G.Lee
