TD 15 TRACKS
LYLE JOHNSON
11-11-2004 15:46:02
5 OR 6 PINS FROZE ON EACH THEY ARE LIKE NEW HAVE TRIED DRIVING ON ROCKS AND THE ROSEBUD WHAT NEXT ?????
T!ROY
11-19-2004 22:12:41
 Re: TD 15 TRACKS in reply to LYLE JOHNSON, 11-11-2004 15:46:02
The problem is they are like new. Not enough interal wear to let moisture out. You will have to have the Pins and Bushings pressed apart with a track press. They will be rusted in pretty tight. Cleaned and reinstalled with a little lube on the pin area inside the bushing. This is a frequent problem with machines that sit for a long time after being used in moist areas. Try M&R Track Service 1-800-564-0383
