Melroe Bobcat 600 aux. hyd.
jmallen
11-12-2004 06:42:04
Having a problem with the aux. hyd. on my 600.
The bucket and lift hyd. work well.
When the back hoe attachment is hooked up and the aux. hyd. (center pedal) is depressed the engine starts to labor and there is no response to the backhoe controls.
Anyone have a remedy?
I think it may be a relief valve in the dual spool control but before I tear it apart I"d like to be sure.
Thanks.
Roy Suomi
11-12-2004 21:28:32
 Re: Melroe Bobcat 600 aux. hyd. in reply to jmallen, 11-12-2004 06:42:04
Are the quick disconnects plugged in fully??Do the balls or points on the disconnects push in. If it worked before it should work now. Before you look for something difficult, check out the easy stuff first.If this doesn't work , remove the quick disconnects off the backhoe and blow air thru the feed line to see if the air comes out of the return line. This is an open center system so air should pass thru valve on backhoe.
