Case 350 track loader
jeffswilliams
11-15-2004 16:50:12
I need info on procedure for adjusting steering clutches on a case 350 track loader
Karen
11-17-2004 06:25:31
 Re: Case 350 track loader in reply to jeffswilliams, 11-15-2004 16:50:12
First, you need to remove the back cover and see what your linings look like. One of the biggest mistakes is not pulling that cover off at least once a year and adjusting it on the inside. If you keep adjusting it on the outside, you'll just wear out the two ends of the brake lining and will not get full efficiency from your brake band. The inside adjustment should be tightened so that there is 1/4" travel on the brake lever at the transmission. Then the outside adjustment should tighten it up to 1/8" travel at the transmission. We reline or sell relined brake linings, use a quality, best money can buy lining (Green Gripper). We get 65 exchange. Also remember, YOU MUST USE GL1 GEAR OIL. It is straight mineral oil. Anything else will damage your brake linings, and effect breaking. If you need linings, manuals, etc., email me and I'll send you a link. We're always looking to buy old brake bands guys have laying around for cores.
agri_con
11-16-2004 03:20:39
First remove both yokes from the foot brake from underneath the tractor.Is there any adjustment left on the nuts(5/8 deep socket)on each side of upper housing?It usually doesnt take much at this area.If not you'll have to remove the back cover which requires drain the gear oil.Inside you'll see the brake bands for each side,heavy wear usuallly occurs at the mounting ends,I use a long pry bar to hold up on the lower end of the band,(first back off the upper adjustment) to remove the pin,take up on the adjustment,and reconnect,if badly worn replace the bands,it can be done by just rolling the old out and new in using some rope and a little bending.
By the way if your interested in selling this machine let me know.
jeffswilliams
11-16-2004 13:02:02
 Re: Case 350 track loader in reply to agri_con, 11-16-2004 03:20:39
so it steers by brakes only and has no clutches, any idea on brake band price?
Windancer
11-16-2004 15:13:08
 Case 350 Brake band $S in reply to jeffswilliams, 11-16-2004 13:02:02
I paid $145.62 each for supposedly
OEM new brake/steering bands for my
350 Dozer (should be same for loader).
I bought them from the local Case IH
dealer, Wolverine Tractor here in southern Michigan. You man find them cheaper thru an after-marketer (probably the same bands)
