putting a backhoe attachment on a case 450
STRESSFREE
11-22-2004 03:11:57
buying a case 450 70,s vintage.it has a counterweight on back.im a welder and mechanic so i can make anything if i know what to make.he said the 530 case and old 580s wheel backhoes have the quick didssconnects on some of them.if not ill have to find a john deere brackets and try to adpact it to the case.any ideas.
John Van Valkenburgh
11-22-2004 16:21:05
 Re: putting a backhoe attachment on a case 450 in reply to STRESSFREE, 11-22-2004 03:11:57
I've got a '68 model 450 crawler that apparently had either a backhoe or more likely a ripper attachment at some time in its life. When I bought the machine it did not come with any attachments but unfortunately it does not have the counterweight either! If you were in North Carolina I'd be interested in your old counterweight. I think these things are on the order of 1100 lbs so it does not sound practical from a shipping standpoint.
I've got bigger problems with the 450 at the moment anyway. It's got a 188 Diesel that has started having a LOT of blowby from the valve cover vent. I noticed last time I started it that there was a lot of smoke and it did not sound like it was running on all 4 cylinders. Its not making the kind of power it should. Time to pull the head and put in a cylinder kit from the sounds of it.
Best of luck,
John
1968 Case 450
DSmolar
12-23-2006 12:57:23
 Re: putting a backhoe attachment on a case 450 in reply to John Van Valkenburgh, 11-22-2004 16:21:05
I am looking to install a Case 33 Backhoe on a Case 450 dozer. Do you have the attaching brackets? If so send pictures of the brackets.
stressfree
11-23-2004 02:49:34
ill keep you ion mind.i will be looking at case 450 carcasses for parts.ill probley find another counter weight.ill be fishing down hatteras in april if i can find one cheap ill hall it down.
11-23-2004 16:03:36
 Re: putting a backhoe attachment on a case 450 in reply to stressfree, 11-23-2004 02:49:34
If you find one at a good price drop me an email at jvan@ipass DOT NET and let me know.
Thanks!
John
1968 Case 450
stressfree
11-24-2004 03:22:39
 Re: putting a backhoe attachment on a case 450 in reply to John Van Valkenburgh, 11-23-2004 16:03:36
ok
mud
11-22-2004 15:31:09
i got them brackets on the back of my 450. it had a backhoe on it before i bought it 8 years ago.
simple looking affair that bolts on. interested?
where you located?
DSmolar
12-23-2006 12:58:40
 Re: putting a backhoe attachment on a case 450 in reply to mud, 11-22-2004 15:31:09
stressfree
11-23-2004 02:53:38
middle pa.
dsarno@epix.net
what tear is your 450.got the manuals last night.any chance you could post a picture.
*ping
11-23-2004 14:01:43
 Re: putting a backhoe attachment on a case 450 in reply to stressfree, 11-23-2004 02:53:38
mud
dave in vermont
11-22-2004 06:06:32
I have just finished adapting a case model 33 backhoe attachment to my JD 350 crawler with JD backhoe brackets. It was not easy as the case unit is slightly different width than the jd. I ended up narrowing the case about 3/4 inch to fit. Lots of cutting and welding 3/4 inch plate steel!
If you tried to use the JD brackets you would have to modify them - not easy as they are very thick steel.
Stick with case parts if you can. Case made a set of brackets for the 450 - model 33 backhoe. Case parts catalog C995 shows this adapter. If you want I can email you a copy of the page from the catalog.
Good luck
stressfree
11-23-2004 02:57:51
 Re: putting a backhoe attachment on a case 450 in reply to dave in vermont, 11-22-2004 06:06:32
yes, send it, i didnt dig in the book yet.if i got the case bracket what backhoe would i need.some say a gas 530 backhoe would fit?
s_ontario
11-22-2004 15:06:31
my Case 320B bought it for $500.00 about ten years ago hand thrown a piston we ran it home running on 3 cylinders found a new block fixed up some lines and she runs great [IMG]http://img38.exs.cx/img38/2471/IM166.th.jpg[/IMG]
Bob/Ont
11-22-2004 15:13:05
 Re: putting a backhoe attachment on a case 450 in reply to s_ontario, 11-22-2004 15:06:31
Hey don't go telling them that. Bad enough they think we aren't firein on all of our cylinders up here, no need to go admitting it Eh.
Later Bob
s_ontario
11-22-2004 15:08:03
third party image
try the photo again
