international t d 7 e Hard to start
james collins
11-23-2004 15:32:50
Can not get it to start with out using starting flood . was wondering if a man can put glow plugs on this machine or if there is another way to pre heat it so stating would be easier
Mal
11-23-2004 23:01:25
 Re: international t d 7 e Hard to start in reply to james collins, 11-23-2004 15:32:50
G'day, sounds like engine compression is down, check your engine valve clearances, if you don't have the correct specs, set 'em to .012 thou for a start.
I've seen a large single gloplug fitted in the intake to the inlet manifold ,where the air filter hose joins the manifold, works a treat!.
