d4 7u pins and bushings
justin wrick
11-23-2004 18:43:27
how much is it for pins and bushings. we'd be putting them in ourselves. also where is the best place to buy them?
T!ROY
11-23-2004 23:10:16
 Re: d4 7u pins and bushings in reply to justin wrick, 11-23-2004 18:43:27
Try M&R TRACK SERVICE 1-800-564-0383. Real good people to work with. Then they will talk you out of trying to install the pins & bushings yourself only to save all your fingers. Unless you have a Track Press to use. Not a logsplitter, not a shop press, not a hydraulic cylinder with a couple plates of steel bolted or welded together. Please for safety sake have a Track Shop install them, either a Dealer or an Independent. Had a customer a few years back tried to save some money. Tried to remove Pins & Bushings in a smaller JD track with a hydraulic vertical shop press. Two fingers lost and a broken nose later, he had his son take them to a professional Track Shop, to embarressed to take them in himself. That was a very expensive lesson. I myself would rather lose a few $ dollars then a few fingers. Just my 2cents
