HELP 350B JD
sht725
11-24-2004 06:21:26
My 350B won"t move when I am turning left under load, Is there an adjustment to tighten the clutch on the right side? Thanks everybody for all your help, you are a great bunch!
Gatractorman
11-24-2004 09:01:05
 Re: HELP 350B JD in reply to sht725, 11-24-2004 06:21:26
Nope no adjustment for this, however you might look and see if you have some free travel between the throw-out bearing and pressure plate fingers if not and the T.O. bearing is contacting the P.P. fingers constantly that will cause it to slip.
PD Mechanical
11-24-2004 13:45:28
 Re: HELP 350B JD in reply to Gatractorman, 11-24-2004 09:01:05
third party image
When checking the clearance be sure to check the right side. This is the side that the problem lies in.
