anybody have a case 450 with a backhoe on it?
stressfree
11-24-2004 14:22:57
want to add one on mine,have all the manuals except that one case dealer is no help.need to know what kind of bracket i need and what hoe goes on it?
stressfree
11-26-2004 03:01:05
 Re: anybody have a case 450 with a backhoe on it? in reply to stressfree, 11-24-2004 14:22:57
looked at a 580 off a cab backhoe.im a welder so i could fab anything.what i see is a L shaped bracket for the bottom holes,and 2 top holes for the top pins.that would mount the newer hoe.the outriggers you could use a doulble spool valve for them.flip farm tracktor seat or a slip in or out boat seat would work.swing is either on petals or on control valve.pull the backhoe off of a cab machine it looks like a 3 point hitch setup just heaver.still would like a bolt on.
jdemaris
11-25-2004 05:28:36
I've got a Case 580CK wheel loader/backhoe ser. # 8336306, (hoe model #33). I've been told that the hoe will fit a 450 crawler, but I'm not an expert. Also told the replacement engine will also fit. It's a beat-up piece of junk, but WAS being used daily until the engine blew. Has a 188 diesel with a rod hanging out the block. Comes with a replacement engine - 207D - (a bolt-in replacement for the 188D). I want to get this crap out of my shop - it's been taking up space for four years now. $2200 in Central New York for the whole works.
jim/pa
11-25-2004 14:41:43
 Re: anybody have a case 450 with a backhoe on it? in reply to jdemaris, 11-25-2004 05:28:36
jdemaris, did you make a deal on your 580ck? im interested if not, im south of you, near bingamton, in upstate pa. can i get directions to look, or a number to call, or give you mine?
thanks, jim
jdemaris
11-27-2004 19:27:03
 Re: anybody have a case 450 with a backhoe on it? in reply to jim/pa, 11-25-2004 14:41:43
Yes, I still have it. I'm tired of screwing around with it though. If you, or someone else is seriously interested, I'll give more information. McFaddens in Sharon Springs is having an auction Dec. 10, and I might just bring it up there and let him sell it.
stressfree
11-28-2004 05:52:59
 Re: anybody have a case 450 with a backhoe on it? in reply to jdemaris, 11-27-2004 19:27:03
yes email me at dsarno@epix.net
im interested in the backhoe but would throw the engine in so the neighbor could plow snow.im going to post question about other motor see if theres any changes ill need.atleast let me look at it before you get bombared with other people wanting to buy it.ill give you an anwser,ill let you know.email me your phone # and address ill see when i can run up.thanks dave
stressfree
11-25-2004 12:34:25
i like what im hearing.where are you located,im 1 hour south of scration pa.im up in ny alot fishing.would like to look at it.you can email me the directions this way it will give me a chance to look at it.thanks dave.
george md
11-25-2004 15:12:47
 Re: anybody have a case 450 with a backhoe on it? in reply to stressfree, 11-25-2004 12:34:25
Dave, I have a parts book with the pictures of the mount for a model 32 case hoe. That is the hoe that is usually on a 450 .I send you an email.
george
marlowe
11-24-2004 17:50:35
got a 450 case with a john deere hoe on it hoe is junk like most deere stuff find a case hoe to put on it
stressfree
11-25-2004 05:21:55
 Re: anybody have a case 450 with a backhoe on it? in reply to marlowe, 11-24-2004 17:50:35
having trouble seeing what kind of brackets i need and hoe to match.found a bracket but case faxed me braket pages and they dont match.how did they mount the jd on your case?
