TD 6 ??
Brad in WA
11-26-2004 23:33:37
When letting the TD 6 set and running, should it be in nuetral with the clutch engaged? Thanks in advance.
king of obsolete
11-27-2004 22:07:27
 Re: TD 6 ?? in reply to Brad in WA, 11-26-2004 23:33:37
head over to redpower bb, we can post pictures. the reason for leaving the clutch engage is the the pilot bearing is not turning all the time. in the great white north we have have the clutch engage or the bearing will burn up due to the cold and grease not flowing. thansk
bcPA
11-28-2004 22:18:59
 Re: TD 6 ?? in reply to king of obsolete, 11-27-2004 22:07:27
How about while parked long term for months at a time?
Kelly/1
11-29-2004 17:58:31
 Re: TD 6 ?? in reply to bcPA, 11-28-2004 22:18:59
bcPA
When parked for long period of time, park with the clutch disengaged, you might also want to take an oil can and squirt a little oil on the clutch linkage and the actuating levers and links when you park it for long periods of time. A little will help it from seizing up after long periods of being idle.
Kelly/1
11-27-2004 18:36:44
Yes, on dry clutches.
Brad in WA
11-27-2004 19:46:21
 Re: TD 6 ?? in reply to Kelly/1, 11-27-2004 18:36:44
Thanks . . .
