Case 850 crawler injection timing
dixie
11-27-2004 06:04:13
I recently aquired an early 70"s model with the Bosch PES pump on right side of the 301 diesel engine. The previous owner had removed the pump and filters(3 stage) and I received them in a box. Got a re-built pump, and installed it at 31" btc on the compression stroke. (per operator's manual}. She starts, but smokes heavily and is'nt hitting on all four. Bled the system more than once and I wonder if I may have lined up the pump itself wrong. The drive gear and the housing have lines on them, and I did line them up prior to insertion. Would appreciate any advice or pages with correct procedure and marks. Thanks
RAB
11-27-2004 14:11:01
 Re: Case 850 crawler injection timing in reply to dixie, 11-27-2004 06:04:13
Find which cylinder that"s missing and try the injector in another cylinder, if nothing else is obviously wrong with the one it"s in.
RAB
operator
11-27-2004 10:39:32
I had a D model do the same thing it was a injector
