What year is a JD450 Dozer ser # 72610
motorhead460
11-27-2004 22:37:30
Hi, was wanting to know what year my dozer was made it is a John Deere plain 450 or possibly a 450B all I can get of the serial # is 72610. Thanks for any help,Rick
2x4
11-27-2004 22:59:49
 Re: What year is a JD450 Dozer ser # 72610 in reply to motorhead460, 11-27-2004 22:37:30
probably 1971
Dave Newman
11-28-2004 12:18:57
 Re: What year is a JD450 Dozer ser # 72610 in reply to 2x4, 11-27-2004 22:59:49
Can you tell me what year my JD450 loader is?
Under the seat is a tag which reads Type: T5E3m and serial # 046736T
and on the dash panel is another tag that reads Type: F7450 serial # 003422U
Dave
Thanks
2x4
11-28-2004 22:09:01
 Re: What year is a JD450 Dozer ser # 72610 in reply to Dave Newman, 11-28-2004 12:18:57
probably 1968 tho it may be a 1967
Kelly/1
11-28-2004 22:27:17
 Re: What year is a JD450 Dozer ser # 72610 in reply to 2x4, 11-28-2004 22:09:01
1968. 1968 started with number 65000, and ended wtih number 82278. 1969 started wtih number 82279.
ohkentucky
01-21-2005 12:22:33
 Re: What year is a JD450 Dozer ser # 72610 in reply to Kelly/1, 11-28-2004 22:27:17
I have a 450 with ser#017505. can you tell me the year? I think it is a 1965, the first year of production. jarvewhite@aol.com
Dave Newman
11-29-2004 15:46:08
But why do I ahve 2 different sets of numbers, and which one is the correct reference
And what about the difference in the "types"? and what do they mean F7450 and T5E3M
Dave
motorhead460
11-29-2004 18:09:03
 Re: What year is a JD450 Dozer ser # 72610 in reply to Dave Newman, 11-29-2004 15:46:08
I know a little about the first numbers or the (type)as it is called. take for instance a T 5C3M ????? ? T, with a T at the beginning this is the tractor serial number.the first digit tells what it is describing T=tractor or E=engine,the second digit is the series 5=JD450,the third digit is the style C=crawler E=loader F=dozer,the fourth digit is fuel type 1=gas 2=diesel,the fifth digit is the type of transmission C=manual M=HLR,the sixth sequence of digits ????? is the production number,and the seventh digit is the manufacturer location T= Dubuque tractor works. If the first digit is a E then that is the engine serial number, for instance M 53TC ????? T ,first digit T=tells it is a engine,second digit 5=4 cylinder,third digit 3=diesel or 1=gas,fourth digit T= dubuque factory,fifth digit is the application C=crawler E=loader F=dozer,sixth sequence of digits is the build number again,and the seventh is the manufacturer again T=John Deere Dubuque tractor works. I think all this info is correct and helps out a little.
