580 case 188 bad will 207d bolt up or do we modifi
stressfree
11-28-2004 05:55:09
not familar with these engines thats why i came to the pros,what ya think.
jdemaris
11-28-2004 19:59:29
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to stressfree, 11-28-2004 05:55:09
I disagree with the other guy. I've got a 188D and a 207D sitting here next to me. They both have blocks exactly the same length, i.e. 20 7/16".
I replaced 188D with 207Ds in the past with absolutely no modifications. I did, however have to swap some parts depending on what machine the 207D came from, and what machine it was going into. For instance, on a 580CK that originally has a 188D and torque converter drive, and using a 207D from a Case forklift, I had to use the orignal 580CK starter because it's a "wet" starter made to have the drive end immersed in oil, and also had to swap front timing covers with water pumps. But, the blocks were sized indentically.
mud
11-29-2004 11:54:09
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to jdemaris, 11-28-2004 19:59:29
you got an extra 188 to turn loose?
stressfree
11-29-2004 14:30:04
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to mud, 11-29-2004 11:54:09
mud if i buy this machine ill sell you the 207d
well shoot!
11-29-2004 20:39:02
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to stressfree, 11-29-2004 14:30:04
then you'll want a deal on these backhoe brackets i bet! hahaha - stay in touch there stressfree.
mud
stressfree
11-30-2004 03:18:02
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to well shoot!, 11-29-2004 20:39:02
i looked at a 450 with a hoe on it they are the brackets.only thing all the top brackets are missing,alot of hardware goes with it almost like the top part of a 3 point.guy will let me know if hell sell me the hoe.if not ill need those brackets to mount another one on it.
mud
11-30-2004 06:17:15
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to stressfree, 11-30-2004 03:18:02
we'll keep lookin for the phone # of that hoe we know about. i do need another engine if you hear of one. can't be an ag, they got a different backside.
stressfree
11-29-2004 03:04:36
jdemaras you want me to come up to take a look at that machine?
stressfree
11-29-2004 02:51:52
i hope you guys stay on board,i might need you if i change that motor.
just 580's
11-28-2004 17:04:53
Yep. The 207 is a little longer block, by an inch or so, which will mean some minor modifications but they should be stress free :).
stressfree
11-28-2004 17:47:23
 Re: 580 case 188 bad will 207d bolt up or do we mo in reply to just 580's, 11-28-2004 17:04:53
works for me thanks
