case 350 Hydraulics
christopher
12-01-2004 11:20:01
Have a case 350 (ser#3065624) and having hydraulic problem..... can raise the blade, but it wont go down.... had similar problem getting the float engaged a while back.... could moisture in the valves freeze and create this problem?? blade worked fine last yesterday, but this morning it wont drop, temps were below freezing last nite... the control lever wont budge when trying to drop the blade, could it be frozen or other problem..... should i try some warm air on it to release or any other suggestions....
christopher
12-02-2004 14:32:05
 Re: case 350 Hydraulics in reply to christopher, 12-01-2004 11:20:01
i am thinking it is moisture in the valves.... it freed itself up yesterday and i could lower the blade (and temps rose above freezing).... today with temps below freezing, the lift lever wont move in either direction and the angle lever wont budge in either direction as well... i tried moving the levers today without the machine running!!!! any ideas???? shouldnt the filter remove moisture from the system?? please help!!!!
