cat injection pump
BSer
12-01-2004 15:12:52
I have a 910 loader with a 3204 engine. Several mechanics have determined the injection pump is wore out. The local cat dealer wants $900 labor plus parts to rebuild it.They said parts generally run $1200-1500. Is there a source of a used pump? Are there independents that can rebuild this? I'm in SW florida and need the machine going but 2K would hurt. Ideas?????
Bob/Ont
12-01-2004 18:30:19
 Re: cat injection pump in reply to BSer, 12-01-2004 15:12:52
BSer, fill us in on some details here. Unless you have been using poor fuel filters it may not be worn out. Well at least not the expensive parts in it.What is happening with the engine?
Later Bob
DAN'S TRACTOR PARTS
12-01-2004 18:01:12
is yours a straight 910 or is it an "E" or "F" model? i should have a inj pump for the 910.
DAN
BSer
12-01-2004 18:51:13
 Re: cat injection pump in reply to DAN'S TRACTOR PARTS, 12-01-2004 18:01:12
Dan,please contact me at cdcreit@strato.net My machine is a straight 910,with a 80u serial number.We bypassed everything and the pump won't maintain a fuel flow..... ..... .maybe my experts are wrong,but I sure need it running. THANKS!
Bob/Ont
12-01-2004 19:04:26
 Re: cat injection pump in reply to BSer, 12-01-2004 18:51:13
Hold onto your 2 grand a minute. What did you by pass? Make sure the fuel line to the transfer pump is free running, drain some into a pail. Then check out the fuel transfer pump bolted onto the side of the fuel injection pump where the priming pump is mounted. On top of the filter is a Tee fitting take off the cap and put on a pressure gauge and make sure you can get 5 psi cranking and about 30 psi running. Then if it doesn't run well think about spending your money on an injection pump.
Later Bob
