Terratrac 500 Continental engine problem
Tractractor
12-04-2004 22:35:40
Maybe some body can shed some light on my problem? I think my motor is a continental 4 cyl gas. It runs but has a miss. Also it has a pretty good flow of bubbles in the radiator. So I'm sure I have a leaking head gasket. I've got the same problem in my forktruck and the motor looks the same. Is this a common problem with this motor and what can I do to fix it right?
Thanks!
george md
12-05-2004 09:30:37
 Re: Terratrac 500 Continental engine problem in reply to Tractractor, 12-04-2004 22:35:40
Head gasket could very well be the problem .when
you have the head off not only check for warp but
check surface for grooving where the fire ring in the gasket makes contact with the head, if
grooved , resurface the head ,check for cracks
as well. There is a group on yahoo for case terratrac
crawlers ,climb aboard . http://groups.yahoo.com/group/caseterratraccrawlers/
george
Tractractor
12-06-2004 15:36:46
 Re: Terratrac 500 Continental engine problem in reply to george md, 12-05-2004 09:30:37
George Thanks for your help. I've tried the yahoo web site before but didn't have much luck getting it set up. I'll look for the problems you described and hopefully come up with a solution.
Thanks again John
george md
12-06-2004 19:40:31
 Re: Terratrac 500 Continental engine problem in reply to Tractractor, 12-06-2004 15:36:46
John, Make the applicaion and I'll make sure
that you get in.
george
