HD 6 overheating
Doug
08-22-2001 13:32:25
All of a sudden this year my allis HD 6 crawler started overheating. The manual says that it shoul run between 165 and 180 degrees. Sinc I bought it, it always run between 195 and 200. I never worried to much about that because it maintained a pretty constant temp and never seemed to have any problems. Now within about 20 minutes of operation, the temperature show over 220 degrees. What should I look for? Has plenty of water/antifreeze in the radiator and I've cleaned the fins with a water hose.
Jeff Pack
08-22-2001 16:25:45
 Re: HD 6 overheating in reply to Doug, 08-22-2001 13:32:25
Could be many things.
As simple as a sticking thermostat, to a clogged
radiator, or water pump going bye-bye.
You could try and backflush the rad, and see if that helps.
