D2 CAT DOZER Diesel motor is stuck
John Lee
12-06-2004 02:11:55
I have a 50's model 3J and the motor will not turn over. I have tryed pull starting it. Got it rolling pretty fast but when the clutch is poped it does not even budge the motor. Any advice on where to start. I am in Yucca Valley, Ca if you wish to come by...
jdabg
12-07-2004 20:55:13
 Re: D2 CAT DOZER Diesel motor is stuck in reply to John Lee, 12-06-2004 02:11:55
Probably got water in the cylinders and is rusted stuck. Put Marvel Mistery Oil in the cylinders and be patient.
John Lee
12-11-2004 18:03:27
 Re: D2 CAT DOZER Diesel motor is stuck in reply to jdabg, 12-07-2004 20:55:13
How can I get water into the cylinders?
John Lee
12-10-2004 16:06:39
Thanks that is GREAT advice, my friend Mike had me do that same thing...
Bob/Ont
12-06-2004 10:10:05
John, take the plate off of the side of the block and see if the rods are free on the crank and the crank free in the mains.The rods shound slide back and forth a bit and the crank move a few.001" to, maybe .025" This will tell you if the bearings are seized or the pistons seized in the liners.
Later Bob
John Lee
12-10-2004 16:09:42
 Re: D2 CAT DOZER Diesel motor is stuck in reply to Bob/Ont, 12-06-2004 10:10:05
I was able tomove the journals after removing the inspection covers.
John Lee
12-11-2004 18:08:44
 Re: D2 CAT DOZER Diesel motor is stuck in reply to John Lee, 12-10-2004 16:09:42
Today I took the radiater off Took the v belt off and tryed turning the crank with not much success. What to do next without taking the head off?
John Lee
01-30-2005 18:27:15
 Re: D2 CAT DOZER Diesel motor is stuck in reply to John Lee, 12-11-2004 18:08:44
she"s not stuck no more just cant find a new head gasket. may put it back together with the old one? tried to start the pony today but just wouldn"t quite get going.
john lee
01-22-2005 20:47:05
today we got around to taking off the head. by tapping on the top of the pistons wiggling the journals tapping the pistons some more prying on the crank and tapping on the pistons some more she finally broke free. free at last. the head gasket looks so good i dont think that i am going to replace it.
