Help What have I got
iaJohn
12-06-2004 19:49:37
How Do All
I recently bought a Ford hoe and am trying to figure out just what all I got so I can get some manuals. The numbers I do know about D5011K mean 4000 industrial diesel no pto 6 & 4 trans. exept this has a 3 cylinder gas. I can't seem to find the engine id. numbers, the web site I found about Ford said they should be under the distributor but I can't see em.So I'll give you all the numbers I can find and any info would be greatly appreciated. Bell housing D5011K , 1B19B , C296512. Engine casting number C5NE 6015C.Hood engine 0J25B. TRANS 0M07B. REAR AXLE 0M03B. UNIT 1B19B. TRACTOR NUMBER C296512.MODEL D5011K. HOE COMPONENT 19-557 or 19-551 it's not stamped real well. Serial RI04348. Well thats all I can see at first glance. The tractor runs real well exept the timing needs adjusted and I don't know where to find the timing marks. I looked at the Ford disscusion board and every thing I read said it was behind a cover on the right hand side again I cant see it if its there.There is on the left side of the beel housing a plate held on with 4 bolts I wonder if thats it? Well thats all I can think of for now, so far I'm tickeled with my purchase it has some wear and this and that don't work like new any more but neither do I and I aint in any hurry. Thanks for your time John
Roy Suomi
12-07-2004 19:59:50
 Re: Help What have I got in reply to iaJohn, 12-06-2004 19:49:37
Oy Vay!! Someone changed out the engine, probably got engine block erosion causing coolant to go into the crankcase from holes in cylinders.The1B19B can be read as follows; The 1 stands for 1971, B stands for February , 19 is day of build , B stands for B shift. [Which is day shift].
