D5C LGP CATERPILLAR
jam
08-22-2001 19:16:22
I HAVE A A D5C LGP DOZER BRAKES WONT WORK ,I REPLACED THE RIGHT HYD. CYLINDER BUT IT STILL HAS ZERO POUNDS OF PRESSURE IT HAS PLENTY OF BRAKE PEDAL THE TRACTOR WILL STOP WHEN BRAKE IS APPILED, YOU HAVE TO PUT IT IN 1ST. GEAR AT FULL THROTLE TO BARELY TURN THE LEFT SIDE HAS 260 LBS. OF PRESSURE BUT WONT TURN . CALLED CAT. THEY SAID YOU NEED BETWEEN 300-600 LBS OF PRESSURE ,THEY ALSO SAID TO REPLACE THE HYD. CYLINDER,COULD THE PROBLEM BE HYD. PUMP? IF SO WHERE? WHICH ONE?
