oliver oc-4 dozer
3040jdpower
12-07-2004 19:08:54
I have a 59" or 60" oliver oc-4 3cyl gas dozer!when you release the clutch pedal it will not move! would that be the transmission filter? if so where is the filter? thank ya"ll for the help!
3040jdpower
12-08-2004 06:45:44
 Re: oliver oc-4 dozer in reply to 3040jdpower, 12-07-2004 19:08:54
a friend of mine said to check the trans filter? i just needed to know if there was one! i do not see it! what else could it be? i check the fluid in the trans!
Mike (WA)
12-09-2004 09:07:30
 Re: oliver oc-4 dozer in reply to 3040jdpower, 12-08-2004 06:45:44
Your friend must be thinking its a hydrostatic transmission- it's not. Just an old fashioned gear transmission, would be referred to as a "standard" transmission if it were in an automobile. There's no filter.
3040jdpower
12-10-2004 16:59:41
 Re: oliver oc-4 dozer in reply to Mike (WA), 12-09-2004 09:07:30
ok when i drained the fluid out of the trans it had water in it! thank ya"ll for help ,this is my first dozer!
jdemaris
12-08-2004 05:48:45
The OC4 has an 8 1/2" double engine clutch and an optional "slo-lo" speed reducer or a "travel reverser" hooked to a gear driven transaxle. I don't know what you are referring too with the "filter."
