Your opinion on JD 350C?
AKDozer
12-08-2004 19:27:13
There is a JD350C dozer for sale in my area. Needs some TLC. UC about 50%. Are they worth owning? Any red flags to look out for?
Mark / ca
12-11-2004 20:45:53
 Re: Your opinion on JD 350C? in reply to AKDozer, 12-08-2004 19:27:13
AK,
As aways, jdmaris has given some great points and things to look for. I'll give ya my 2 cents; I've got 2 350C's and find that their size is great for my needs on my lands. Just like everything, they have there place. I tow with a 1-ton, put in many many miles of roads, cleared a lot of brush etc.. They have never let me down other than sometimes I had wished it was bigger, (then I get on the 450) however sometimes wished it was smaller.
The 350's are a great dozer for their size, if used correctly and could last a very long time. Keep in mind that this is not a good tractor for removing stumps, working in super rocky soils or thinking you can grade a few hundreds yards of dirt as fast as a D-8. Good luck.
jdemaris
12-08-2004 20:23:24
Yeah, it's worth owning if you NEED it. It IS what it IS, a small crawler. Other than checking the obvious, e.g. engine, reverser function, steering clutches and brakes (they're wet), here are a few things particular to the 350C series to look for: #1 look underneath where the reverser case bolts to the transmission case. Two large nuts on studs (takes around a 1 1/8" wrench). Make sure they look tight and there is no evidence of movement or shifting between the two cases. If there is, don't buy the crawler. #2 Check the two side frames where they bolt to the final drive clutch housings. Look for rewelds or cracks. If they ARE cracked, look for further related problems, e.g. cracked or loose clutch housings and/or final drives. #3 Check the cast cross-bar that the track frames are fastened to. 1010s and 350s have always had problems here, but different sytems are used depending on vintage of machine. 350C uses a "floating" track-frame system. So, the trackframes are bolted to the crossbar with floating dowels that hammer up, down, and sideways when the crawler is used. They often break, or wear the metal down to near nothing. So, check for loose and/or missing bolts and dowels, thin/worn fastening areas, or . . . parts that have already broken and someone trying welding the whole mess fast. It NEEDs to float or something else will break. I don't know why Deere didn't install a tranverse spring like CAT or AC uses. 450 series Deere crawlers don't have the wear or breakage problems the 350s have.
stressfree
12-09-2004 02:27:49
 Re: Your opinion on JD 350C? in reply to jdemaris, 12-08-2004 20:23:24
to small unless your in sand.my 450 case gruts when it comes up to mountain oak.thats alot heavyer than a 350.good for manure.
jdemaris
12-09-2004 06:37:08
 Re: Your opinion on JD 350C? in reply to stressfree, 12-09-2004 02:27:49
350 was our most popular crawler, in dozer form, for loggers and for rental. It is good for bunching logs for the skidder and for small road building. Kind of useless for pushing stumps. Also a very popular dozer for grading and such in loose soils - but NOT hardpan. We sold quite a few to rock cutters, using them to open slate quarrys. It tore them to pieces. I'm in central New York State and everything is hard pan. Back in the 60s I worked for a Deere dealer in New Jersey where everything was clay and sand. The 350s were great there and virtually lasted forever. We used to sell quite a few 350 crawler-loaders with hoes on them in Jersey. Great digging machines but also very underpowered. Again, in my area of hardpan - Deere 450 series is MUCH more machine - especially the late B series (with turbo) and on. Or in my case, I use an Allis HD6. It's cruder than a 450, but just as rugged and powerful. I love the 344 cube Buda engine.
