Track pads for HD5G
fstraight
12-09-2004 04:29:54
Looking for track pads,semi-grouser,cant find anybody that can get new ones.Prefer along the east coast.For my HD5G they are 13in.I have read that 6s will work.
hector gemme
02-11-2005 05:55:30
 Re: Track pads for HD5G in reply to fstraight, 12-09-2004 04:29:54
HI I HAVE SOME HD5 USE PARTS
jdemaris
12-09-2004 06:29:15
HD5 is basically the same machine as the HD6 - but the 6 has a different engine. Allis got in a feud with Detroit Diesel and started using Buda engines. The HD6 has the Buda 344 four-stroke-cycle diesel engine. Tracks are the same pitch for both, but in either machine they come in different lengths. Some use 33 pads per track; some 37, etc. Berco has new pads available but only in 18" width (as far as I know). $19 each. In a pinch, guess you can cut them down. I come across used tracks fairly often for loaders with flat pads (semi-grouser). I need some dozer pads with high grousers. My pads are curled over so I don't think it's worth trying to weld on new grouser stock. HD5A and HD5B are supposed to be 33 pads per track. HD5F and HD5G are supposed to be 37 pads per track. HD6 was supposed to be as follows: 6A before #5100 - 33 pads. 6A after 5100 - 34 pads, 6B before 5100 - 33 pads, 6B after 5100 - 34 pads, 6E, 6EP, 6PS - 37 pads, 6F,6G - 39 pads. 13" wide pads was standard on all of them. 10"s, 12"s, and 14"s were also available. They came as semi-grouser (loader), full gouser, snow & ice cut-out grouser. Bolt on protective plates were also available for street use, part # 235926.
fstraight
12-10-2004 04:18:49
 Re: Track pads for HD5G in reply to jdemaris, 12-09-2004 06:29:15
Thanks for the info,I will contact Berco to see if pads are still avaliable.
