Will A Torque Converter Wear Out?
StuckRusty
12-09-2004 16:14:26
My Hough HAH Payloader has a two-speed tranny with torque converter. It seems to bog down going up a slight hill. The fluid level is good in the T-C and the clutch seems fine but it takes full throttle to bearly get up the hill and doesn't have the torque to scoop up a decent bucket of loose dirt. I can't justify the expense if the T-C needs replacing on this worn-out machine.
Bob/Ont
12-09-2004 16:34:30
 Re: Will A Torque Converter Wear Out? in reply to StuckRusty, 12-09-2004 16:14:26
They do sometimes get lunched but usually the seals wear and they leak. Before you go too far make sure the trans pump is good. They take most of the pump flow to charge them and keep them running cool. If the stater in the center breaks loose they will kill the engine and go nowhere.
Later Bob
StuckRusty
12-10-2004 17:10:38
 Re: Will A Torque Converter Wear Out? in reply to Bob/Ont, 12-09-2004 16:34:30
A transmission pump, huh! Maybe I had better break down and purchase a service manual. This problem and a bad brake master cylinder(easy to replace) are the last items keeping this hulk from being very useful. As you can see in the Tractor Photo section my Hough HAH has sheet metal badly rusted but mechanically it works OK.
Bob/Ont
12-10-2004 18:42:17
 Re: Will A Torque Converter Wear Out? in reply to StuckRusty, 12-10-2004 17:10:38
You need to check the pump pressure at high and low throttle settings and compare. Most hold 90 % of High setting, pressure at low setting but you should check a manual to be sure. If you can get a manual it will save the expensive guessing and parts changing.
Later Bob
d aprile
03-04-2005 20:20:19
 Re: Will A Torque Converter Wear Out? in reply to Bob/Ont, 12-10-2004 18:42:17
I would suspect it is an engine problem. Could be as minor as fuel or air filter. Generally if the torque is screwed she'll slip.
