Case 450 dozer
sstiving
12-09-2004 23:02:32
I am getting a case 450 from out of state, threw a rod through the block. Does anybody happen to know the weight, length and width of one of these machines? Or maybe a website that might have this info? I would hate to drive all the way down there and not have a truck and trailer big enough to haul it home. Also, does anybody know if I will be able to pull this onto the trailer without it running? Any help would be greatly appreciated... as I know nothing about dozers. Thanks.
sstiving
12-10-2004 23:14:50
 Re: Case 450 dozer in reply to sstiving, 12-09-2004 23:02:32
Not sure which rod it threw yet, it is my grandfather's and he just put a remanufactured motor in it about 2 years ago, just used it around his farm... he is not very mechanical or good at checking fluids as the original motor froze and cracked and this one was run low on oil. He just told me that there is a rod thru the side of the motor. I hope to raise the blade somehow and try to chain it up, and winch it up or pull- push with his tractor. I was told that was possible, but just wasn't sure if it would "roll" freely.
Jean C Marleau
12-10-2004 19:29:49
A 450 diesel crawler Dozer weighs 10,729 and a 450 Crawler loader 14,224 LBS with 14" grousers.
F. J. International
12-11-2004 02:09:50
 Re: Case 450 dozer in reply to Jean C Marleau, 12-10-2004 19:29:49
We need Crawller Dozer with Ripper HYD. Operated & Control , water cooled Turbo Charged Diesel Eng ,310-330 HP. Semi-u-Blade Cap: 8.75-9.75M3, work. Temp : 30-60 C, Ripper Digging depth780-880 MM, Power Shaft Transmission Min. Turn. Radius 3.6-3.8M, Steel Cabin ( Rops / Fobs) with standerd equipment, Japan/usa/Polish origen.
Urgently require ( 7 Pcs )
stressfree
12-10-2004 03:09:56
yes lift blade and chain up.winch or push on with other machine.where did it throw a rod? #4 drivers side?
stressfree
12-10-2004 03:10:43
 Re: Case 450 dozer in reply to stressfree, 12-10-2004 03:09:56
6 ton
