Case 310 Crawler
JWR
12-10-2004 08:07:39
Does any one know where I can find the final driveshaft outer bearing and COMPLETE OIL SEAL.
When I pulled the driveshaft I found that the oil seal and spacer had been replaced with a sealed bearing (outer houseing had two bearings)and driveshafe cut down so the bearing would fit. I don't want to ground down my new shaft so would like to find original oil seal.
Thanks for any help you can give me.
case poor in pa
12-11-2004 02:37:29
 Re: Case 310 Crawler in reply to JWR, 12-10-2004 08:07:39
try don .l manifold@smig.net
JackMapes
12-10-2004 16:55:38
Those parts should be available at a Case dealer. The bearings and seal you can find at a bearing an seal place. I"m thinking that driveshaft is hooked up to your pinion gear, if I remember correctly.
