JD350...again!
JimInOz
12-11-2004 22:39:50
Hi guys.Found out that I have broken springs on steer clutch pressure plate.Very hard to find until I took it all apart.Can someone quote for supply of the 6 springs,please.It's a JD350 loader,T4E3D 0738581.(If you can't supply springs,I need spring strength specs,so I can get them made.)Thanks to previous guys who have helped...think I'm on right track now.
JimInOz
12-17-2004 01:01:40
 Re: JD350...again! in reply to JimInOz, 12-11-2004 22:39:50
I got a guy to make some springs,so if anyone needs some ,I'll get a quote .Cost a lot to get initial few drawn up/etc,but I can order more at anytime.JIM.
JimInOz
12-12-2004 12:21:01
Thanks guys...all helpful,as usual.I tried ordering these parts thru local Australian JD Agent,but he couldn't supply.I thought I'd have more luck in the US.
jdemaris
12-12-2004 06:21:34
I don't think Deere will sell individual parts for those pressure plates. Back in the late 70s, early 80s, as a Deere mechanic, I tried to buy springs, release fingers, etc. and they were not available. The entire assemblys were fairly cheap at the time; perhaps not anymore. I believe the OEM plate assembly has dual coil springs. Outside springs test at 250-276 lbs. at 1 9/16" length, and inside springs 83-91 lbs. at 1 1/2". When you reassemble, make sure you use Neverseiz or an eqivalent on the adjuster bolts.
PD Mechanical
12-12-2004 05:39:01
third party image
We have new pressure plates available. Check out our website at www.pdmechanical.com for pricing and more information. Part # AT18886.
Pete/ME
12-12-2004 03:32:13
"...on the right track..."--please. Puns will be punished severely!
Got my torsional isolator springs from JD. Try to get the part# on the JD site.
