Help on JD 440 3 pt. part.
John Bertram
08-23-2001 22:28:42
I have a JD 440 crawler with the factory 3 point hitch. I need help in finding a lifting arm for it. The local dealer says the part is no longer available. The part I am looking for is the lifting arm insert. On the 440, the end of the lifting arm can be slid out to adjust the implement distance from the tractor. Unfortunately it was designed with adjustment holes in the square shaft that make it prone to failure. It had been repaired when I bought the tractor and has broken twice since I have had it. Hopefully one of you may have a source for me.
george steele
08-27-2001 05:23:36
 Re: Help on JD 440 3 pt. part. in reply to John Bertram, 08-23-2001 22:28:42
I've heard of a place in Pa. Smoky Mountain tractor parts that has many 440's for parts. Not sure of area or if that's correct name but I remember it as Smoky Mountain ect..ect. Hope you can find them. I'll look in my reciepts and see if I have any info. for you. Good Luck.
