Case 188 diesel parts needed
BKahler
12-15-2004 15:37:20
Finally got the pan and head off our 1963 case backhoe and found the reason for the loud knocking was a spun rod bearing on #1. There was almost nothing left of the bearing, light score marks on the crank and more on the rod. So, I'm in need of a good used connecting rod for a 188 diesel. Also need a replacement water pump pulley. Something chewed off the back part of the pulley.
Thanks,
Brad
870-329-1335 or email at
brad.kahler @ 141.com
jdemaris
12-16-2004 05:49:53
 Re: Case 188 diesel parts needed in reply to BKahler, 12-15-2004 15:37:20
I've got a blown-up 188D from my old 580CK that has #3 rod out of it - the rest seem to be fine. If you don't find a rod elsewhere, I'll sell you one. I assume your rod is so bad it cannot be resized? You should have all your rods checked for a round hole and bearing shell crush and, if needed, get them all resized. It's standard procedure for any diesel repair/rebuild.
DAN'S TRACTOR PARTS
12-15-2004 17:11:14
brad
DO YOU HAVE A CAST # OFF OF YOUR OLD ROD?
DAN
BKahler
12-16-2004 02:58:45
 Re: Case 188 diesel parts needed in reply to DAN'S TRACTOR PARTS, 12-15-2004 17:11:14
Dan, I'll have to look after work tonight when I can get over to the shop.
Brad
