HD 6 e crawler for sale
Eddie Livengood
12-18-2004 14:20:22
I have a HD6e crawler for sale. Engine runs good,
everything works,needs a drive axle and outboard bearing assembly,and new track.Had a new clutch installed .
Has a cargo winch . Located in central North Carolina.
hector gemme
02-07-2005 12:32:11
 Re: HD 6 e crawler for sale in reply to Eddie Livengood, 12-18-2004 14:20:22
HI I HAVE A SHAFT FOR HD6 AND MANY PARTS.
ACEd
12-19-2004 19:21:27
What S/N / config of blade - cable vs hydraulic and adjustments and how much? I unhid my e-mail as the moderator may wish that either you post in classifieds or we take off line.
Eddie Livengood
12-20-2004 17:13:31
 Re: HD 6 e crawler for sale in reply to ACEd, 12-19-2004 19:21:27
I cannot find the serial #,it's not on the rear housing that I can find. It has a 344 engine, hydraulic blade, straight blade that you can manually tilt or (angle ?) We bought the dozer for the track for a HD5g. I ran it long enough to load it and unload it. The left rear outboard bearing was completely gone and messed up the drive axle, the axle could possibly be repaired?
The winch works, no problem with the hydraulics, engine ran very good, transmission worked fine, steering worked fine. The batteries need replacing. There is a canopy on it.NEEDS Painting!The front Idlers are in good shape also the rollers.I wanted to fix it, but my son wanted his loader.The pads for the track are in good shape, but the rails with it are off the loader and are worn out.The rear sprockets are in very good shape.The man I got it from had put a clutch , bearing and (pressure plate?) in it 2 years or less ago with very little use on it.He had replaced the starter, I have the old starter which is repairable.I have removed the axle but could put it back together to move it I think.
I would like to have $2000.00 for it.
fstraig
02-03-2005 03:00:33
 Re: HD 6 e crawler for sale in reply to Eddie Livengood, 12-20-2004 17:13:31
Do you still have a HD6 for sale? If so were are you located?
Eddie Livengood
10-28-2005 17:51:18
 Re: HD 6 e crawler for sale in reply to fstraig, 02-03-2005 03:00:33
Sorry, I haven't been to this site in a while.
I still have the HD6e, The dozer runs good ,good hydraulics,new clutch, cargo winch, needs painting. The drive axle was bad,I purchased a new one but have not had time to put it in. The dozer needs a set of rails.I have a old set off an HD5g, but they are only 36 links and don't know if they will work.They are worn out, but if they will fit you could possibly load it with them. I'm located in south central North Carolina. Thanks, Eddie
