belt change on a case 450
stressfree
12-19-2004 16:59:49
pain in the a$$ remove hood,radiator muffler air cleaner,then try to pull pump.drain hydralic tank,then go to pull pump someone when installing a new pump stripped the bolts so they made a round backing plate with new 1/2" holes to hold pump in.ok it works but you cant loosen the pump bolts at the crank.they had the backing plate tacked in 3 places so i got the die grinder out and cut the welds.off with the pump.why not just drill and retap holes to 9/16".also is there a front motor mount bolt or pin?when i was prying the pump it would pry up.if its a broken bolt ill have to drop pan to get to.
David in SC
12-20-2004 02:55:55
 Re: belt change on a case 450 in reply to stressfree, 12-19-2004 16:59:49
Stressfree,
My belt is shot too. When it fails, I thought about trying one of the adjustable link style belts. My pump mount appears to have some of the same "modifications" that you mentioned. I put one on a tractor at work about 1 year ago and it works fine. A little late for you, but do you or anyone else have any experience with them?
Thanks,
David in SC
stressfree
12-21-2004 03:05:35
 Re: belt change on a case 450 in reply to David in SC, 12-20-2004 02:55:55
not realy those belts are spare tires only.they dont hold up on something that spins that fast.its better to do it right.atleast now i could tell you how to do it.also the bolts are out of the bottom of my radiador and possibly my front motor mount.
Dale(MO)
12-20-2004 19:23:51
David,
I replaced 2 on my friend's HD5 with 2 new ones, and I thought they were really great. On it, you would have to drop the grill, radiator, and possibly the hydraulic pump to put on regular V-belts, but the linked belts went right on and worked like a champ. I'm not sure of the age of the ones we replaced, but they were definitely not new! I would recommend them for just about any V-belt application that requires a lot of disassembly to install. Happy Holidays!
RJM
12-29-2004 18:49:47
 Re: belt change on a case 450 in reply to Dale(MO), 12-20-2004 19:23:51
Looking for track rollers for HD5 AC dozer. Do you have any info on where to get parts?
stressfree
12-21-2004 03:07:51
anybody know if that front motor mount is a bolt or a pin.my parts book dont show it.
stressfree
12-23-2004 13:09:39
 Re: belt change on a case 450 in reply to stressfree, 12-21-2004 03:07:51
lifted up motor and it is still connected by bolt.must have a rubber bushing thats wore out.have to drop pan to fix.winter project.
